CanadianTaff
Automotive
We have a piece of equipment which was designed to be supplied by 1000VAC, the customer informed us late on that the supply would be 1100VAC.
As a solution an auto-transformer was used to drop the supply to the designed level.
Now when the power is applied the main breaker trips due to the transformer centre tap being connected to the earth instead of neutral.
There is no available neutral to the equipment which is remote and we cannot install a new earth.
What would be the result of disconnecting the earth and leaving the unbalanced load floating?
Is there another solutuion apart from replacing with larger, heavier, expensive alternatives to the auto-transformer?
