Auto Dimension
cadman64
18
Where did my autodim command go in Solidworks 2008?
In drawings? Select import annotations when creating the drawing, or Insert->Model Items.
If you're talking about in the model, look at DimXpert.
Jeff Mirisola, CSWP, Certified DriveWorks AE
Dell M90, Core2 Duo, 4GB RAM, Nvidia 3500M
Ok, I figured it out. Was looking for a command icon and there isn't any, they stuck it on a tab when you click "Smart Dimension". UI Problem solved.
:0)
SW Help]Autodimension a drawing
You can use the Autodimension tool to insert reference dimensions into drawing views as baseline, chain, and ordinate dimensions.
To autodimension a drawing:
In a drawing document, click Smart Dimension on the Dimensions/Relations toolbar.
Select the Autodimension tab.
Set properties in the Autodimension PropertyManager, and click OK .
[cheers]
