AUTO CAD
Chemical
PL
How can I convert multiple dwg files to pdf in windows 10. actually I can convert but the problem is dwg convert to pdf with coloured line and and text. I can not do monochorome multiple file convert.
Appreciate for respond.
With Bricscad, it's in the plot options when you print and in the plotter styles you select.
You can screen capture and create PDF from clipboard in Acrobat. If you are printing to PDF, that sounds like a problem in your printer settings.
TTFN (ta ta for now)
I thought that's what his problem was and directed him to the plot/print manager.
IIRC, there is a Batch Plot function in ACAD. You do have to set your plot style to use B&W and I think you can plot extents, but it has been a long time since I used it.
_____________________________________
I have been called "A storehouse of worthless information" many times.
Have you tried the publish command ?
