I'm trying to design an automatic balancer to balance a fan attached to an electric motor. I've made a disc withh a groove containing a few steel balls which are free to move around to conpensate for the fans unbalance. This assembly seems to do a pretty good job of reducing vibration but there's one problem. Since the motor is mounted horizontally, the balls all drop to the bottom of the disc when the motor stops. This causes a grest deal of vibration at start up until the assembly can re balance itself. I've considered filling the groove with a grease or fluid to help the balls retain their position while the motor is stopped. Any suggestions as to what material to use? The assembly must operate outdoors year round.
jon
jon
