Attempting a new area and needing some help! 1
tongy66086
I am working in an area that I have never messed with before and am hoping that someone here can help me out.
I am working on some drawings to send out to casting companies for quotes, etc. The first part I'm working on is a ball joint type of connection.
I have attached a pdf of what I have so far, but you can see I am needing to "blend" the flat surfaces into the ball surface.
How would I do this, and does solidworks have any tutorial on this?
Thank you for your help and suggestions.
I clicked the link and it opened just fine, but will attach it again. This time, I attached my solidworks part file, rather than a pdf.
I have no idea where in the tutorials to look for what I am trying to do.
My solidworks experience has been exclusivly in the sheet metal area, so I am trying to fumble through this.
 http://files.engineering.com/getfile.aspx?folder=cc8ca56b-06a1-4bf1-9010-c44f53650d15&file=BALL_JOINT,_2_INCH.SLDPRT
Applying a fillet to the two interface edges worked for me.
Are you receiving an error message?
Must be on my end. I have never seen this message before.
I click on the link to download, I get...
"Duplicate headers received from server
The response from the server contained duplicate headers. This problem is generally the result of a misconfigured website or proxy. Only the website or proxy administrator can fix this issue.
Error 349 (net::ERR_RESPONSE_HEADERS_MULTIPLE_CONTENT_DISPOSITION): Multiple Content-Disposition headers received. This is disallowed to protect against HTTP response splitting attacks.
I'll go with the other's to resolve your issue.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Actually, if you first apply a Fillet to the two tiny edges where the flat faces meet, and then apply a Fillet to the edges adjacent to the sphere, the result is much better.
I have SW 2012 and this means you can´t load my file after modifications but here are the results from adding a few fillets.
The important thig is to not try and add all fillets at the same time. use multiple features. and try to turn off "tangent propagation" to see if you get better results in some freatures.
the other solution is to sketch 3d curves onto all faces you want to smooth between and make a surface that is tangential to its surounding but fillet is easiest by far if it gives you good enough results.
 http://files.engineering.com/getfile.aspx?folder=4715df1e-b380-4d64-b3b4-8e1eca41f9d1&file=BALL_JOINT,_2_INCH.1.jpg
Thanks a million!
The jpeg looks almost like I envision
it to look in my head.
I will give this all a shot.
Thanks again to everyone.
Chris I'm also getting the errors "Duplicate headers received from server"
Are you using Google Chrome? I didn't get the error using Internet Explorer 8
Pat
