I have a 46mm keyed shaft and I need to secure a sprocket to it. The sprocket has a 66mm hole and a 4 mounting bolts on a 108mm bolt circle.
Is there a quasi off-the-shelf solution? Can I buy a keyed hub in the correct size and weld on a custom flange?
Thanks,
b
Thanks,
b
