slickdeals
I have a situation where I have a glass + polycarbonate roof supported by steel trusses.
The trusses span about 12m and are spaced at 3m o.c. Since I don't have any diaphragm at the level of the glass, I am planning to introduce horizontal X bracing to function as a diaphragm.
This atrium is at Level 4 of a 35 story building. There will be structure on all 4 sides rising above this glass roof. As such I won't have to worry about any wind loading. I plan to have a sliding connection on one end so that these trusses don't form part of any lateral resistance.
My questions are:
1. How much force should this X bracing be designed for? I think the primary role is to prevent compression flange movement. There will be infill members spanning 3m between trusses to support the glass.
2. Will any bridging be required in between the trusses? I won't have any net uplift but I like to brace the bottom chords.
3. Any other items to be considered other than deflections to be compatible with that of glass?
Thanks.
My questions are:
Thanks.
