Based on the reflux stream temperature, how can I determine if aqueous droplets will form in the tower, potentially causing corrosion? Do I check if the reflux temperture is colder than the condensation temperature of water at the tower operating pressure? Or do I use the free water formation temperature of the vapor flow in the top section of the tower?
Using the condensation temperature seems not reasonable for me because condensed water droplets will disolve in the condensed hydrocarbon droplets.
Any opinions/ideas?
Any opinions/ideas?
