Thanks for your help.
I am working on WF 4.0 - VS 2005
Inedd to create user interface for Asynchronous application using MFC.
I Found settings @
http://www.ptc.com/cs/cs_21/howto/ptk1725/ptk1725.htm
But its giving following errors.
1>stdafx.cpp
1>Compiling...
1>MFC_Demo2.cpp
1>d:\nandini_2012\mfc_demo2\mfc_demo2\mfc_demo2.cpp(76) : warning C4996: 'CWinApp::Enable3dControlsStatic' was declared deprecated
1> c:\program files\microsoft visual studio 8\vc\atlmfc\include\afxwin.h(4474) : see declaration of 'CWinApp::Enable3dControlsStatic'
1> Message: 'CWinApp::Enable3dControlsStatic is no longer needed. You should remove this call.'
1>MFC_Demo2Dlg.cpp
1>Generating Code...
1>Compiling resources...
1>Compiling manifest to resources...
1>Linking...
1> Creating library D:\Nandini_2012\MFC_Demo2\Debug\MFC_Demo2.lib and object D:\Nandini_2012\MFC_Demo2\Debug\MFC_Demo2.exp
1>libcpmt.lib(cerr.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>protoolkit.lib(srcnet.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>protoolkit.lib(srcstream.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>protoolkit.lib(srcstdstream.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>libcpmt.lib(cout.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>protoolkit.lib(srcbase.obj) : error LNK2019: unresolved external symbol __invalid_parameter_noinfo referenced in function "protected: virtual char const * __thiscall std::ctype<char>::_Do_widen_s(char const *,char const *,char *,unsigned int)const " (?_Do_widen_s@?$ctype@D@std@@MBEPBDPBD0PADI@Z)
1>protoolkit.lib(stringsrc.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>protoolkit.lib(osapisrc.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>protoolkit.lib(nmscomm.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
1>D:\Nandini_2012\MFC_Demo2\Debug\MFC_Demo2.exe : fatal error LNK1120: 1 unresolved externals
1>Build log was saved at "file://d:\Nandini_2012\MFC_Demo2\MFC_Demo2\Debug\BuildLog.h tm"
1>MFC_Demo2 - 10 error(s), 1 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
And i have tried the setup given in
http://www.purplerose.biz/Vin/new_page_2.htm
Here am getting following errors
1>------ Rebuild All started: Project: MFC_Settings, Configuration: Debug Win32 ------
1>Deleting intermediate and output files for project 'MFC_Settings', configuration 'Debug|Win32'
1>Compiling...
1>stdafx.cpp
1>c:\program files\microsoft visual studio 8\vc\atlmfc\include\afx.h(24) : fatal error C1189: #error : Building MFC application with /MD[d] (CRT dll version) requires MFC shared dll version. Please #define _AFXDLL or do not use /MD[d]
1>Build log was saved at "file://d:\Nandini_2012\MFC_Settings\MFC_Settings\Debug\Buil dLog.htm"
1>MFC_Settings - 1 error(s), 0 warning(s)
Because I have selected configuaration type MFC Application output will be .exe. but i have selected runtime libraray MDd as given in the document.
Can you please help me .
Thanks in Advance
Nandini.S.L
