Assy configuration
Mxious
Hi it's me again !!
Is there a way to made different set-up of the same assy and put it into a draft ?
Ex. Suppose I have a door who move with a cylinder. I want to make 2 view in a draft in the two position:
Door closed (cylinder out)
Door opend (cylinder in)
But I wont delete my constraints, create 2 assy or anything like this.
Please help !
I would suggest to use 'Alternate Position' assembly for that.
You should find a description in SE's help
dy
Donyoung you're right on as always!
The way I normally do this is to create the cylinder as an Alternate position assembly so I have the cylinder position retracted and extended available, then I use it to control the position of the door in an Alternate position assembly of the door itself.
I hope my explanation is not too confusing!
Pat
Hi PatCouture !
Are you speaking french ? Si oui j'aimerais communiquer avec toi pour des question plus technique sur SE !!
A+
Salut Mxious!
Tu as reconnu mon accent :P
Mon courriel est le pro-machpatrickc (arobase) videotron.ca
Ça va me faire plaisir.
Patrick
