Associate XYZ coords on a drawing to 3D coordinates
autoengineer79
4
Hi all
I couldn't find any recent threads on this (newer than '09 time frame).
Like may other companies we have XYZ coordinates of holes in a chart on the face of the drawing and just got bit because they are non-associative to the 3D and did not update with the 3D. PRO-E had simple ways of updating several features on the face of the drawing by entering the value as an attribute name &drawing name&, &revision level&, &dimension 1 X coord& (or something like that, its been a long time) so that when the variable updated, that forced the item on the drawing to update as well. Is there a way that CATIA can associate the 3D X,Y,Z to the chart on the drawing for R19? Also, data is stored in SAP.
Scott
Coordonate dimension table is not associative (last time i checked).
I could see only one option for that: create 3D annotation with linked XYZ (with attribut link) for each points (by script), then use view from 3D to project points and annotations.
Works with R20.
Eric N.
Ferdo,
Thanks for the suggestion, but as you said after, not associative. The only thing that I found that works is to recreate the table every time, which isn't really that good.
I feel like there should be a way to do this though....!!!!
I can put a point at the center of the hole, measure it(Measure.1) Gx, Gy, Gz, create a parameter for each of the coordinates Hole_1_Center_Gx,Gy and Gz publish the parameter(s) and have it drive a hole in another part, but can't figure out how to get the drawing table to know that I want a value in the table to be 'Part355\Parameter: Hole_1_Center_Gx' which is equal to Measure.1 Gx. Though this seems like it should be a built in function.
Eric,
How do you get the text in the annotation to be anything but user entered text?
go right click in the text field to find the hidden attribute link.
Eric N.
