Dear Mr. Fergal_Hatt
Q. "... I have no idea how to wire up this Crompton PArkinson motor (forward or reverse) ..."
A1. My sincere apology for the long delay due to the following reasons:
a) I emailed the manufacturer on two separate dates, but received no reply,
b) I did a "Google" and "Yahoo" search on Crompton Parkinson's Single-phase motor (wiring diagrams) but none that matches the wiring shown in your picture 1.
A2. Based on your Pic 1, showing 3 terminals
(Z) ,
(AZ),
[A?]; each terminated with two different coloured conductors, while Markings (K), (S), (T) are not in use. I tried to figure it out. It is "likely" a
single-phase split-phase motor with centrifugal switch , without starting capacitor. See attachment for wiring. Attention: This is my assumption. It is
NOT published by the manufacturer, see above A1. b).
A3. Proposed power source connection:
Power supply source shall be connected to terminal
A and
AZ. Polarity is immaterial. Earthing wire (coloured
yellow-green) shall be connected to the motor frame, without failed.
A4. Based on the assumed wiring, the motor is intended to operate a single [
fixed direction of rotation]. The (direction of rotation) does
NOT change when the [source conductors are inter-changed].
Che Kuan Yau (Singapore)
