Assing moment of inertia to an assembly
amubashar
93
I am trying to run a motion analysis study on an assembly. I have assigned mass and centre of gravity but I can't find how can I assign moment of inertia. Any help would be appreciated.
Hi
Thanks for the reply. I want to assign I values from centre of mass. I have modelled a simple representation of the actual assembly for use in motion analysis. Any idea ?
I guess I just don't understand how you would _assign_ the moment of inertia. Isn't that a result of the material density and geometry of the object relative to the axis? If you want to manipulate I you have to vary the geometry.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
He's talking about motion analysis, not just modelling.
It's been a few months, but I recall that the parameters for inertia were on the same interface as those for CG and mass, arranged in a 3x3 grid.
Thanks TheTick
I expected the inertia to be on the same interface as CG and mass but (I am using SW2011) when i choose the option of assigned mass properties in mass properties dialog box, only mass and centre of gravity options are there.
Unfortunately, I do not have access to the full SW Motion at my new job. Can't help further.
