struclearner
Dears,
When the shell elements are created at the mid surface of a plate, the thickness value of the plate, assigned to shell elements goes to both ways, i.e. 1/2 value is assigned to either side of the mid surface. When the shells elements are placed on the solids elements, as a surface coating to extract the stresses at the outer surface, or for quick evaluation of the structure thickness sensitivity upon the stress/strength, the thickness assigned to shell elements laying on the solid elements should go on the outside direction only.
Please comment if my understanding is correct and how we can assign the thickness value going in one direction only in a FE program/solver.
Thanks for the help.
