Assigning Macros To Keyboard Shortcut
Wow... Sorry CBL! This method's been around since something like '02!
-handleman, CSWP (The new, easy test)
Although I do think that assigning a macro to a mouse gesture is new.
[lol] I knew a macro could be assigned to a key, but I meant via the new Keyboard shortcut customize dialogue. Previously only the macros placed in an install directory were available.
SW2011 and earlier;
If Macros is not listed, you must create a macro folder and record a macro in your SolidWorks installation directory, as described in the first procedure.
No, the keyboard shortcut customize has been around a long time. Perhaps help just sucked? I've never made a macro folder, and I've always used this method to assign macros (from multiple folders on local and network drives) to shortcut keys. The key is that you have to have a button mapped to the macro, then you can assign the key to the button. If I read your first link correctly, that's still the way.
OK, just me then. [sad]
Agreed. [lol]
I don't think I had ever used the button method, so always had to create the Macros folder. Now we don't need that folder or the button. So I'm happy.
