Assembly Question
Mitsu50
Hi all,
I'm trying to reduce the file size of an assmebly by saving it as a single part file. Theproblem is that when i do this, the file size of the part file doubles in size. I tried all the options of export when saving as a part file, but nothing works. Am i missing something here? I successfully did this on another assembly i'm working on, it cut the file size in half for me. I'm running SW 04 with SP3.0 Thanks in advnace!
Are you counting the size of the original assembly AND all of the component files in your comparison?
i'm comparing the size of the assembly file (18mb) to the part file i created from the assembly, that is now 26mb.
My thoughts exactly Tick. If you look at what makes up an assembly file, it is relatively small. A bunch of pointers to part files and some mating information. I think you would be hard pressed to reduce this by saving the assy as a part. But when you take into consideration the handling of all the parts that make up the assy, you have a lot of data to keep track of. I have had success doing this with off the shelf assemblies that I received from vendors (where I would never have to change their parts). But the file sizes are usually bigger than if I just modelled the item as a single part altogether. The time saved is the key factor in that instance. It was desirable for me to not have to keep track of all the sub-components of the manufacturer's part.
My recommendation, is to tinker around with the options to save exterior faces, exterior components, and all components until you get the smallest file. I have had the best success with the exterior components selection.
Are you trying to save file size on where the file is stored or the amount of memory it takes to load the single part vs the assembly?
