When working with an assembly, I'll often open the file with no components then use the 'component name' column to pick and choose which components I need to open. In some files, names in subassemblies show up just fine; in other files you have to open the subassembly (structure only, not loading components) before the names will show up. In some assembly files some subassembly component names show up while others do not. I would like all the names to show up without having to open subassemblies.
What is the difference? Why do some names show up before you load the subassembly and others do not? Is there some setting I missed or difference in technique? Is there a way to change those that don't show up so that they will?
This is one of those minor annoyances that has bugged me on every version of UG/NX I have worked on.
