Rattler,
The products I mentioned are used in high-volume applications for automobiles. If you can't use the lubricant as a pre-applied type, I would try the Macdermid product shown above - I believe it is a simple immersion product, while the others are more complex polymers that require baking to cure the coating. All of this information is for high precision applications. If you can work with less precision, then simple grease, waxes, and oils will be satisfactory.
Cory
