I made a toothless belt in the part file. Then inserted the belt. Then I used a the profile of a gear in the assembly to create a cut-extrude in the belt. Then I used a curve driven pattern to create the teeth around the entire belt.
After reading your comments and trying out your suggestions,
what I am finding is that I can propagate the cut-extrude back to the part file but the curve driven pattern does not have a feature scope section, however it is easy enough to recreate the curve driven pattern in the part in this case. In the case that I had a more complex pattern is there a way to propagate a pattern back to the part?
