how to do a extrude (not extrude cut) in assembly mode itself
if we have a assembly & to any one of it's part we want to add suppose a solid cylinder in assembly mode itself .how to do this with extrude command available in assmbly mode.
You can create part features in assembly mode. Just pick the part, right click & select activate. Now you are working on the part while in the assembly. Just be careful what you reference!
If you do this its a wise idea to check your references while your in the sketch mode. To do the just look at your sketch pull down menu choose references. In the pop-up box if there any references to any other parts or the main assembly delete them. You will now have to replace them with the datums from that part.
