Thanks for all the help I have had on this site so far.
1. On my project I could not mate two parts in assembly. One was essentially a block with screw clearance holes, the other was a plate with tapped holes. I could mate two of the holes with concentric, but when I picked the faces that would be coincident (Bottom of block and top of plate) I was given an error that the two faces were not parallel. The problem was one face was .000378 deg off being horizontal. That is such a ridiculously small number for what I am making is there a way to increase the tolerance of mates? Or at least to tell the software that .000378 deg is close enough?
2. So I am working on another project and for simplification purposes lets say I have two plates and two hinges to connect them. I make my "hinge" as a separate assembly since it is something that we use all the time. On my project assembly I insert my first plate, then I insert my hinge sub assembly and mate with screw holes to "plate 1". Then I insert my 2nd plate and mate to the other end of the hinge sub assembly. Very simple" two parallel plates attached by a hinge.
Now when I try to "work" the assembly (rotate one half of the hinge and plate2 about the hinge point with the move component command) it will not move. So I go check the "hinge" subassembly and I can "work" one half the hinge so there are no restrictions there. I go back to my project and double check my mates and there doesn't seem to be anything holding it up. It seems to be problem of using sub assemblies within another assembly. It just seems like such a stupid a problem I must be missing something in order to make it work. So how can I "work" this assembly?
