A
Arbalete
Guest
Hi everyone
This is a beginners question and the answer may be totally obvious for the seasoned Solidworks user.
I imported numerous CATIA assemblies into solidworks and saved them each separately. Then I started to work these assemblies into one single large assembly by the command 'insert assemblies'. With all the parts and assemblies in the right place I saved the file. When reopening the file however the error 'unable to locate assembly file' message pops up although the file path and file name are all correct. Further I am being asked to direct to the location of the file which then opens nicely. So it seems that I fail to safe the assembly correctly.
What can be the reason?? Is there something I missed when assembling assemblies?
