Teo5082
Chemical
- Jul 7, 2016
- 1
I have done a subroutine for a membrane simulation in Aspen+.
I compiled sucessfully and obtained an mem2.obj.
I created a shared librairy with asplink command.
I gathered all the file in one folder and defined it as my working directory.
Finally, I refer to the name DLOPT text file: Membrane_Loc_dll.opt in the run setting. When I run the simulation I have the following error messages:
Processing input specifications ...
STRUCTURE FOR COMPONENT CARBO-01 HAS NOT BEEN DEFINED.
PCES CANNOT USE GROUP-CONTRIBUTION METHODS TO ESTIMATE MISSING PROPERTIES
USE THE STRUCTURES PARAGRAPH TO DEFINE STRUCTURES OF THIS COMPONENT.
STRUCTURE FOR COMPONENT WATER HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT OXYGE-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT NITRO-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CARBO-02 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT NITRI-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT SULFU-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CALCI-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CALCI-02 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CARBO-03 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT HYDRO-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT SULFU-02 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT ARGON HAS NOT BEEN DEFINED.
* WARNING IN PHYSICAL PROPERTY SYSTEM
PARAMETER PC/ELEMENT 1 (DATA SET 1)
UPPER BOUND VIOLATED FOR COMPONENT CARBO-03
VALUE = 0.22300E+09, UPPER BOUND = 0.10000E+09
PARAMETER DHVLWT/ELEMENT 1 (DATA SET 1)
UPPER BOUND VIOLATED FOR COMPONENT CALCI-02
VALUE = 0.22559E+10, UPPER BOUND = 0.60000E+09
PARAMETER DHVLWT/ELEMENT 5 (DATA SET 1)
VALUE = 3670.0 , UPPER BOUND = 1500.0
PARAMETER FREEZEPT/ELEMENT 1 (DATA SET 1)
VALUE = 4300.0 , UPPER BOUND = 4000.0
* WARNING IN THE "STREAM" PARAGRAPH WHICH BEGINS ON LINE 149
STREAM NAME: COAL
THE SUM OF ATTRIBUTED COMPONENT VALUES IS NOT 100.0 FOR
COMPONENT: COAL TYPE: PROXANAL
IN SUBSTREAM NCPSD OF STREAM COAL .
STREAM NAME: COAL
COMPONENT: COAL TYPE: ULTANAL
*** SEVERE ERROR
ERROR DURING DYNAMIC LINK OF USER ROUTINE(S) OR IN-LINE FORTRAN
PLEASE CHECK FILE _1300avb.ld FOR LINKER MESSAGES.
*** SEVERE ERROR
COULD NOT RESOLVE USER OR IN-LINE FORTRAN SUBROUTINE(S):
SUBROUTINE "MEM2" IS MISSING
*** SEVERE ERROR
PROGRAM TERMINATED DUE TO UNRESOLVED ROUTINES
I checked if my fortran compilator is well installed and linked to aspen+ (
If you any tips or suggestions, you are welcomed.
Thanks in advance.
STREAM NAME: COAL
STREAM NAME: COAL
*** SEVERE ERROR
*** SEVERE ERROR
*** SEVERE ERROR
Thanks in advance.
