Cibachrome brings up a good point - but I don't think it is the one he was trying to make.
The original tires on your BMW were RunFlats. Those are quite different than regular tires and if you change out of those, there will be quite a few differences on top of what normally occurs when changing tires.
However, I am going to disagree with Ciba in that:
1) If the exact tires are still in production (not likely due to the age of the car!), they will be generally available - as in if the tire dealer doesn't have them he can order them - and the BMW dealer is not the only source.
2) If the exact tire is out of production, suitable replacements (RunFlats) will also be generally available. The car dealer is not the only source.
But you haven't responded since the first post, so we don't know much about what your goals are in the change. If you read this, please let us know what you'd like to have in a tire. That way we can perhaps advise you better.
