pastyl
- Feb 7, 2009
- 37
At a beu heat exchanger the tubesheet is fixed and gasketed on both sides by channel flange and the shell flange.
In case o-ring gasket is used (m=y=0) there is a contact surface between channel flange and tubesheet and the same valids for shell flange and tubesheet.
However the contact surface is not extended beyond bolt diameter.
My question is if ASME VIII App.2 or App. Y is suitable for flanges & bolts stress calculation.
