The U-1 Data Report should list the joint efficiency on Line 8. If you don't have a U-1 it's possible that the joint efficiency was listed somewhere on the original drawing, or if the MAWP was listed it may be possible to back-calculate the joint efficiency.
Otherwise if you have documentation to back up that all of testing outlined in U-68 was performed, the efficiency E = 0.90. Otherwise, E = 0.80 as long as the requirements of U-69 are met.
-Christine
