I have tried to understand which is the safety criteria behind this roule, but there is something that do not work fine (I'm in the classical situation in which a flat surface pass or not pass in function of the value of the factor C. Staybolts: Tubes of OD=120 mm x WT=8mm; Flat Circular Plate: OD = 1600 mm x WT = 15 mm; P= 11 bar.g @ 250°C SA-516/70).
I know the SAFETY criteria: the MIM thickness of a flat stayed surface is the thickness of a circular plate which diameter is the MAXIMUM diameter that may be inscribed inside the path array of the stay bolts (The CODE "semplify" considering the Max Diam. as the MAX Pitch in the Center of the Staybolt Array Pattern, in all possible directions).
I know that the formula reported in UG-47 is the formula to design flat circular cover and that the value of C should reflect the edge constraints (Simply Supported or Fixed Circular Plates).
UG-47 Formula: tr = Pitch x SQRT( P / S / C)
From Theory (Annaratone, "Pressure Vessel Design" Ed. Springer - Page 220 Chapter)
- For Fixed Edge: SQRT( 1 / C) = 0.285
by which, C = 12.31
- For Simply Supported Edge: SQRT( 1 / C) = 0.454
by which, C = 4.85
But, if I assume:
1 / C = 0.285 -> C = 3.5
or
1 / C = 0.454 -> C = 2.2
I get (quite) the same figures stated inside ASME Par. UG-47(a)).
May I suppose that my discussion is right and that ASME has forgot to implement the SQRT operation?
Somebody can explain me which is a possible fault in the above reported discussion?
Many thanks to all.
by which, C = 12.31
by which, C = 4.85
But, if I assume:
or
Many thanks to all.
