jakov11000
There is a center tubesheet, welded to shell on both sides.
Per ASME VIII-1, what would be requirement for the "tp" value in this case?
See below sketch.
Would ASME VIII-1 consider just the center part of the tubesheet as "tp" (same OD as shell), or is it safe to consider that "tp" actually starts from the other face of the tubesheet and ends at the weld the other side.
See below sketch.
