I have read some threads in here about the minimum pressure requirement on Section VIII Division 1. However, I am still confused as to when it is acceptable to design a vessel per div 1 for a pressure higher than 3,000 psig. Many of you have said that you have seen vessels stamped with div1 for higher than 3000 psig but that an experience engineer should be consulted...well I did...but I am still confused.
We have designed a vessel per Div 1 and the criteria is as follow...12"OD Schedule 160 Helium vessel with a MAWP of 3,992 psig and ambient operating temperature. The Authorized Inspector wants us to justify the use of Div 1 at this pressure.
I spoke to a senior engineer and he basically told me that since we have no other loading (no occasional, no nozzle load, no thermal gradient, etc) other than gravity (which should relieve the circumferential stress) and internal pressure that it would be OK to use div 1. However, doesn't div1 allow you to take into account other loadings? I think understand the analysis differences between div1 and div2 but can't wrap my head around the div1 limitation when pressure is higher. And...what max pressure can you get away with using div 1?
In advance, thanks for your help and response.
