ASME Sec VIII Div. 2 - New Construction using Old revision 1
Faree
Petroleum
PK
Hi Experts
We are going to build new vessel per ASME Sec VIII Div. 2.
Can we build new vessel as per old drawings and code revision (pre 1999). If yes then safety factor & stress should be used of old or new revision. please share reference of code.
Thank you TGS4!!!
So what is the answer? for those of us interested but without a copy of the code.
LittleInch - build to the current Edition.
Thanks, I thought it might be something like that.
There's usually a grace period when you can keep building to old codes when things are in process, but that sounds like a good plan once the code becomes officially published. But not 20+ yrs....
