Hi All,
I'm trying to use the ASME RTP-1 code to calculate the minimum allowable thickness of a torispherical head on an FRP tank. The equation I'm using is 3A-230, it's the first case:
t = (M*P*Rc)/(2*(Su/F))
I'm now unsure of the pressure value, P. The formula doesn't really define it in this paragraph, and I've narrowed it down to two options:
[ul]
[li]Maximum internal pressure (ie. hydrostatic head when tank is full, in my case)[/li]
[li]Maximum external pressure (weight of the nozzles and a 250 lb live load)[/li]
[/ul]
The hydrostatic head (1st) case is obviously the higher value, but intuitively I don't trust it. I see this pressure affecting the hoop stress of the cylinder a lot more than the tank head. The pressure of the liquid would push against the walls of the tank, and expand the vessel in all directions.
However, I believe the stress due to that process would also translate to the tank head.
Can anyone give a little bit more insight on this matter?
Thanks and regards.
Aljosa Mitrovic
Mechanical Engineer
[ul]
[/ul]
Thanks and regards.
Aljosa Mitrovic
Mechanical Engineer
