I quite regularly see stop valves on the discharge flanges of "high pressure" (15-150 psi) steam boilers. It is my understanding that the piping between the boiler and the first valve must be ASME piping. Many mechanical contractors do not have the ASME stamp, so valves are connected directly to the boiler flanges in order to comply.
How would this be accomplished if the boiler has a threaded connection? I have a situation with the boiler has a 3" threaded coupling for the steam discharge connection. Even if I use a threaded valve, there will be a nipple in between the boiler and valve. How do I comply with ASME?
Thank you.
Thank you.
