ASME IX P# issue 2
chas49
Industrial
Jan 19, 2006
6
We have inadvertantly used an AISI 1006 material for membrane attachment to waterwall tubes. We normally use 1008 or 1018 which are P#1 materials in ASME IX. Although AISI or SAE 1006 is listed as ASME 5041 in SA29 of section II A we cannot find an assignable P# in ASME IX for procedural purposes. Has anyone had this problem?
Membrane attachment welding is not pressure boundary material. As such, non-pressure boundary material can be used provided it is weldable. Revise the WPS to allow for unassigned P-No material.
I believe any un-assigned base metal requires qualification under Section IX.
chas49;
You have a nonconformance, which can be easily dispositioned without having to replace it by establishing weldability. The 1006 is very close to 1008 carbon steel in terms of chemical composition and weldability. Revise the WPS by requalification using the same material used for membrane. That is it.
Thanks gentlemen. Sort of what I guessed I will have to do but you can't blame a guy for trying.
