Hi,API 1104 states "This standard covers the gas and arc welding of butt, fillet,and socket welds in carbon and low-alloy steel piping used inthe compression, pumping, and transmission of crude petroleum,petroleum products, fuel gases, carbon dioxide, nitrogenand, where applicable, covers welding on distributionsystems" It does not say anything about water. I'm interested in pipelines of 6-10" that'll carry water from frac' ponds, inpoundments, and water bodies to frac' locations. I'm thinking that ASME IX welding procedure applies more to it since of of the B31 codes addresses water.Is it better to use ASME IX for such application, or API 1104 even if API in the scope did not mention water at all.Advice please?
