engineer0
- Nov 7, 2021
- 5
This is a bit of an overlapping question regarding Federal Regulations, ASME Code, and a specific application, so hopefully this is the correct thread to post in.
How much of ASME B31.8 is applicable to CFR 192? I understand 192.7 states what ASME Codes are incorporated by reference, but under the respective section, it states "IBR approved for §§ 192.112(b); 192.619(a)"? Does this mean that B31.8 language was adopted for those sections only? Or does it mean that B31.8 in its entirety now needs to be adhered to when designing gas transmission and distribution facilities since it was incorporated into the CFR?
More specifically, I'm dealing with specifying integrally reinforced branch outlet fittings or O-lets for some transmission and distribution class facilities. Since 192.155 Welded branch connections (under Subpart D) is very general in its requirements, does it mean I could technically use an o-let that meets B31.1 or B31.3? Or since 192 references B31.8 is all of it applicable and I need to specify that the o-let meet B31.8 requirements?
Let me know if my question makes sense or not. Thank you for any consideration on this matter.
