mitulmech
- Sep 22, 2011
- 10
Dear Group Members,
I have following query related to subject post
Design Code : ASME Sec.VIII Div.2
Design Pre : 320 bar
Design Temp : 85 Deg C
Inside Diameter (ID) : 187.3 mm
Cylinder Required Thickness is : 24 mm
Material of cylinder : SA 350 LF2 CL1
Material of attached flange : SA 350 LF2 CL1
Pressure rating : 2500#, ASME B 16.5
Equipment : Pig Launcher
Due to specific inside diameter (ID) requirement cylinder outside diameter (OD) is coming = 187.3+24+24 = 235.3 mm
But B 16.5 STD. hub outside diameter at bevel end shall be not larger than the 219.08.
Query :
If we increase hub outside diameter at bevel end to 235.3 mm to match the same with cylinder OD keeping all other dimension as per B 16.5.
Still can we qualify this flange standard flange as per B 16.5 or it will be custom design flange and need to be perform thickness calculations?
What is tolerance limit of deviating from STD. OD of 219.08?
Static Equipment Engineer
Query :
