When standard pipe flanges to B16.5 (or any other standard) are used as main girth flanges in a heat exchanger for example, how does one calculate the bolting moments to transfer to the tubeplate?
Although the pressure/temp rating is adequate for the service it is always difficult to prove the standard flanges to ASME VIII appendix 2, especially when you use gaskets such as Spiral wound with higher m & y values.
Does anyone have any guidance to how I should calculate the Mop and Matm values and what bolt stresses should be used, actual applied or code stress?
Many thanks in advance
