ASME B16.34 / Body Minimum Wall Thickness
Basic inner diameter values are used as parameters related to wall thickness and consequent pressure rating, and inside diameter is the nominal bore value, which is related to flow calculations.
I work with valves in exotic alloys at alloy-valves.com. This is me on Twitter and LinkedIn. Let's connect!
