749KDV
- Feb 7, 2002
- 38
If a Section VIII vessel normally operates with a gas bubble, but under extreme circumstances can be lined up to fill the tank solid, does one need to protect the tank from over pressure with a gas relief AND a water relief? Would Section VII code requirements for overpressure protection be met if one could provide a gas relief for normal operation and use administrative guidelines i.e., procedures, to ensure that the valve line-up that would fill the vessel solid never happens?
