bookowski
- Aug 29, 2010
- 983
What are the correct load combos to use for ASD wood design based on IBC '09 and 2005 NDS?
1605.3.1 lists 'Basic Load Combinations' for ASD. In 1605.3.1 it states that stress increases specified in the material chapters shall not be used with these combos 'except that increases shall be permitted in accordance with Chapter 23', where Chapter 23 is Wood.
Alternative combos are given in 1605.3.2 which state that they should be used where stress increases are allowed by the material chapter. These combos are generally all 1.0, i.e. D + L + Snow etc.
For wood I am taking the 'stress increase' to mean the duration factor. The way 1605.3.1 reads I would think that I am allowed to use the 'Basic Combinations' along with the duration factor (stress increase). However, in looking at the solved problems that come with the NDS I see that they always use 1.0 factors on all loads indicating that they are referencing the 'alternative combos' (although they don't explicitly state where the combos come from).
