onsitepower
Hey guys, hopefully someone can help me with this issue. I have an ASCO series 300 ATS 3 phase 120/208 400 Amps. When utility power fails it sends the signal to start the generator as it should, but it does not transfers to emergency. I have check voltage line to line and to neutral and hertz and everything seems correct. Even the emergency power available light at the membrane is lit. I manually transfer to emergency and when utility returns it will retransfer and shut down the unit properly. I removed the control board and installed on another ATS same voltage and amps, and it works perfectly. Just in case I also replaced the rectifier bridge with no results. The coil seems to be working since it retransfers. I have talk to ASCO but they pretty much want to send a tech to verify the unit. What am I missing?? I will appreciate any advise.
Kind regards
Kind regards
