SteelPE
- Mar 9, 2006
- 2,766
This question is in regard to a building being enclosed, partially enclosed and open in relation to ASCE 7.
If I have a square structure that has a gross area of each wall = 10,000 square feet with each wall having 2,000 square feet of openings in each side. This building would not fall under the partially enclosed section of the code because Ao < 1.1Aoi. However, the building would not be classified as open either since Ao<0.8Ag. So does that mean that the building would be considered enclosed?
The codes says that an enclosed building is any structure that does not fall under the partially enclosed or open definitions so therefore it must be defined as enclosed.
Also, how would interior stud walls effect the calculation of Aoi? If you have stud walls that run from floor to ceiling, I would think that you wouldn’t be allowed to use the area of openings enclosed by the stud walls. Now, if the stud wall comes within 4’ of the roof because of a suspended ceiling, how would that effect the calculation of Aoi?
