Schambach
- Jul 31, 2001
- 31
The pre-2010 ASCE 7 used a minimum wind pressures of 10psf on the vertical projection of the entire building and then in 2010 and thereafter the minimum pressures are 16psf on walls and 8psf on the roof. This thread is not about ASD vs LRFD, I found posts on that, this question is about the legitimacy of the minimum pressures acting on the vertical roof projection found in Section 28.4.4. For buildings with a roof slope under 30 degrees (Fig 28.4-1) the net force acting on the roof in the direction of the wind is NEGATIVE. Note 6 (Page 301) says the total MWFRS shear shall not be less than that determined by neglecting the wind forces on the roof.
Can somebody explain why with laboratory-defined pressure coefficients we have to ignore the effects of the roof that actually "pulls" the roof back towards the direction of the wind, thus lessening the overall shear on the MWFRS? And if that truly is the case, isn't neglecting the roof pressures for roof angle degrees < 30 conservative? Isn't throwing an 8psf pressure against the vertical projection that is POSITIVE, when in actuality it is negative REALLY conservative? Is that really what ASCE 7 wants the engineer to do?
I read the ASCE 7 such that both pressures need to be applied to both vertical projections........no questions asked. Some engineers I know choose to disregard the minimum roof pressures on the vertical projection because in reality they've already conservatively estimated the roof shear. Am I looking at this wrong?
Thanks.
Thanks.
