swearingen
The referenced load combination is:
0.6D + 0.7E + H
Assuming no pressure loading (H), my question is what weight are we to use to calculate E?
I understand that the 0.7 is from NEHRP changing the code to produce factored loads instead of service level, so when using ASD, you must lower it, and for LRFD it is 1.0.
I also understand that the 0.6 is there as a conservative measure because the dead load in this overturning case would be helping you.
What I don't get is why you'd use the full weight of the structure to calculate E and then try and restrain it with 0.6 of the weight. Can we use 0.6 of the weight to calculate E? Or is this not permitted?
0.6D + 0.7E + H
