I am designing a canopy and want to confirm I am using the updated codes correctly if any one has knowledge of the 7-16 code expansion. It seems pretty straight forward find the GCpn from the chart below (attached) and multiply it by the wall wind pressure. My canopy is low on the building falling within hc/he < 0.5, This gives me a canopy uplift and downward force of less then my wall pressure. My hesitation comes in when this value is compared to roof overhang values, which is what I used for canopies before ASCE 7-16, the overhang pressures are over 3-4x higher then the new canopy pressures, hoping someone can explain why this is, and that this is indeed how the code is supposed to be used. Its possible I am supposed to add the loads to the canopy twice, (once for each face, similar to a parapet), any help would be appreciated.
