If I have a Type 4 Irregularity - Re-Entrant corner, the code states I can't use the Simplified Wind Load method because of the stipulation in 6.4.1.1. This method uses the zones labeled in Figure 6.2 and pressures in the following tables. However, I specifically remember my professor leading us through that procedure on an L-shaped building (re-entrant corner). Was that the wrong method to use or does one of the other procedures follow the same tables? I know that we had to design the drag strut and collector through the re-entrant corner, but everything else followed simplified method. We did break up the building to have two "a" zones on the outside corners. Any insight would be appreciated.
