Hi all. I have a simple question, but i cant find the answer.
I know how it works the ASBA command.
ASBA,AREA1,AREA2,,KEEP/DELETE,KEEP/DELETE
The question is simple, how can i with this command,select more than one area? For example
If AREA 1 is cut by area 2 and 3 (AT same time), how can i select on "AREA2", the area 2 and 3 at same time. BETTER, WHAT is the command?
Well, it should be possible, because in ANSYS, is possible to pick more than one area in this option, but only manually. I need to know the command.
Thank you for your time
