Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
What does "legally binding Deemed-to-Satisfy" mean? The deemed-to-satisfy options are not legally binding unless I'm missing something.(i) AS 2870 is legally binding and provides Deemed-to-Satisfy provisions.
Is there a direct quote from the NCC that says this?(ii) In case of conflicting information between NCC and AS 2870, the one with the more conservative values should be used.
Can you clarify what this means? An expert can show that a solution "is at least equivalent to the Deemed-to-Satisfy Provisions." The expert would not need to override anything.(iii) An expert is not allowed to override a Deemed-to-Satisfy provision.
I think you would need to clarify some of the statements. Some of your conclusion contradicts the quotes from the NCC, or needs further clarification to support the conclusions.
LiamJS said:(i) AS 2870 is legally binding and provides Deemed-to-Satisfy provisions.
Only the performance requirements are mandatory. There are multiple ways of demonstrating compliance with the performance requirements, one of which is AS2870 in the deemed-to-satisfy provisions. This does not mean that AS2870 is the only method of demonstrating compliance.
Is there a direct quote from the NCC that says this?LiamJS said:(ii) In case of conflicting information between NCC and AS 2870, the one with the more conservative values should be used.
Performance requirements can be complied by Deemed-To-Satisfy Solution, so AS 2870. Hence, to comply with NCC we have to comply with (a) the Governing Requirements of the NCC; and (b) AS 2870 (If we choose to use Deemed-To-Satisfy provisions). What happens if they conflict? They shouldn't, this is the annoying part. However, they do. What will we do? This part is my interpretation. I say that we should comply with both of them.LiamJS said:Quote 2-) Document: NCC 2019-A1 – Part A2
“A2.0 Compliance
Compliance with the NCC is achieved by complying with—
(1) the Governing Requirements of the NCC; and
(2) the Performance Requirements.”
An expert can show that a solution "is at least equivalent to the Deemed-to-Satisfy Provisions." and that expert can also go below it but the only way to do this is to provide a performance solution. For example, an expert can do a performance solution and can use smaller depths for the footings than those given in AS 2870 as Deemed to Satisfy Solution.Can you clarify what this means? An expert can show that a solution "is at least equivalent to the Deemed-to-Satisfy Provisions." The expert would not need to override anything.LiamJS said:(iii) An expert is not allowed to override a Deemed-to-Satisfy provision.
Sorry I misread your post. I guess in terms of "AS 2870 vs NCC" it really comes down to what you're comfortable with.I didn't say "legally binding Deemed-to-Satisfy". Building act 2012 makes NCC legal document and NCC makes AS 2870 a legal document to satisfy Deemed-To-Comply-Provision. (There are other ways such as expert opinion but I am focused on Deemed-To-Comply and "AS 2870 vs NCC" here).
All of the codes conflict. AS2870 conflicts with AS3600. Try designing the ground slab mesh as per AS3600 and see what you getWhat happens if they conflict? They shouldn't, this is the annoying part.
No mate you have to use some engineering, please.
