thread561-225906
Hi, I've made some searches and it seems I can't find a definite answer.
My concern is I have an unequally spaced bolt pattern on a circular diameter. Using the instance function isn't much of a time saver so I used 2 sketches and two hole functions. The reason I have two functions is I need two different bolt length in this assembly. I thought that I could use array in multiple add from "add component" but the function seems to be unable to recognize the hole function as an "array".
So finally my question, is there a way to use the hole function (that is based on many sketch points) to add multiple component without constraining them all 1 by 1?
Alex
Alex
