BUGGAR said:
jgKRI, I am looking for drivers' experiences with these cars. I did the numbers and I'm looking for verification because I can't believe the flexibility I came up with either. A second analysis from another engineer is welcomed (I was able to enter the coordinates and materials into Risa and play with it within a day.) I watched videos of these cars on the track but how can you "see" flexibility without telltales? I have correspondence to a couple of kit car people but their knowledge of engineering seems to be limited to cad drafting(?!)
How effective was tuning your car with anti-roll bars? I don't mean to ask race secrets but did adding/subtracting the bars front/rear have a lot of affect. Thanks.
I am happy to share my experience.
For background, I am a reasonably experienced driver- in a past life I was a national-level Solo II competitor. I'm not a superstar but I know which pedal makes the car go so to speak.
I do not own an Atom, but I have a friend who does. I have spent approximately 10 track days (and counting) co-driving his Atom with him, at Gingerman here in Michigan or at Mid-Ohio. I have never (and never will) 'compete' in an Atom so I have no secrets to hide.
The car I have seat time in does NOT have antiroll bars front or rear. I know that there are atoms out there which have them- this particular car does not. It does, however, have the upgraded Ohlins damper package which was available at the time, and it has also been changed to a single coil vs. the stock helper-spring setup.
The base characteristic of the car out of the box was toward mild understeer at turn-in- at low speeds and with even halfway decent tires, it would molest the bump stops mid corner.
Removal of the helper springs aided this somewhat, by getting away from the rising-rate spring behavior that induced a lot of roll. The single coil is also one step stiffer on the chart of options available for the Atom- I would have to dig with my buddy to remember what the actual rates are front and rear.
I've found the car to be relatively easy to tune- after fiddling with damper settings over several sessions, the car is at a point now where mid-corner balance is easy to tune by adjusting bound damping in the rear.
